I put mine right in front of the engine, to the side of the plug. I went from the thru-hull to a threaded vs. slip adapter, to the T, and then to my ball valves. The trick (IMO) on getting all this assembled is to use slip pvc fittings. Where you use solvent and epoxy, not threaded w/plumbing tape. I ended up putting mine together in three parts. front, rear, and thru-hull. This way I assembled the ball valves, pumps, hoses, wires, etc. then just fit the whole thing to the T w/ a slip fitting. you may need a few more fittings than you planned on, but its worth it. just make sure you "dummy" assemble it (no epoxy, loosely threaded) to make sure it all fits where you want it.
