Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 15, 2006
Old     (cvnrides)      Join Date: Feb 2006       02-10-2006, 4:36 PM Reply
Just bought some new Kicker KS 60's for my 2002 launch and it looks like the grills will not cover the factory speaker mounting holes. Has anyone else had this problem? The factory speakers have a large bolt pattern for a 6.00" speaker. Does anyone make an adapter ring or should I just make some? I could just fill the holes in the glass in the middle a rear but the front bolt holes are thru the vinyl.Thanks
Old     (mikeski)      Join Date: Aug 2003       02-10-2006, 4:49 PM Reply
sounds like the factory speakers are 6.75" units, it would be best to take advantage of the larger footprint with a bigger cone speaker - like the Polk DB675 or the good ole Pioneer TSA-1780
Old     (cvnrides)      Join Date: Feb 2006       02-10-2006, 5:04 PM Reply
The factory speakers are the el-cheapo type that the grill and speaker are all one piece, the holes are drilled way out on the edges. The cutouts in the boat measure 5.25". Would the larger 6.5 or 6.75 speakers fit this hole?
Old     (dudeman)      Join Date: Mar 2005       02-10-2006, 7:06 PM Reply
Mikeski is right. I had the same problem and went with the db675.
Old     (cvnrides)      Join Date: Feb 2006       02-11-2006, 8:11 AM Reply
Randy, did you have to enlarge the holes to fit the db675?
Old     (dudeman)      Join Date: Mar 2005       02-11-2006, 9:11 AM Reply
Vince. I did have to enlarge the holes. I used a sawzall. Also had to remove a few panels to cut for the ones in the back.
Old     (gharvin)      Join Date: Oct 2005       02-13-2006, 4:34 AM Reply
kicker has a 6 3/4 spealer the ks65
