THe shaft alignment is pretty simple to do. Loosen the coupler where it meets the transmission and slide it apart slightly. Put a .010" feeler gauge in at the 12 o'clock position, slide the coupler and tranny together so that the gauge slides somewhat snug. Then check the measurement at 3, 6, and 9 0'clock positions. It should all be at .010", but you have some wiggle room. As long at anything from .013-.007" can fit all the way around you are good. If it doesn't all line up in these measurements, you need to move the engine to make it so.
