Old    tribal            05-12-2003, 9:27 AM Reply
Got a new let's go ride sac with filling nozzle m instead of female.It seams to cause a small airspace which makes it next to impossible to prime the pump to drain the sac.I've drained it 3 times now and tried all dif technicues including pre priming the pump.Help!
Old     (typhoon)      Join Date: Jul 2001       05-12-2003, 9:34 AM Reply
draining from top or bottom?
Old    tribal            05-12-2003, 9:47 AM Reply
Top
Old     (typhoon)      Join Date: Jul 2001       05-12-2003, 9:49 AM Reply
aerator pump? when you are priming, do you stand on the sac?
Old     (typhoon)      Join Date: Jul 2001       05-12-2003, 9:51 AM Reply
sean, let's hook up sometime. we ride coyote after work once a week if possible since anderson is closed.
Old     (typhoon)      Join Date: Jul 2001       05-12-2003, 9:52 AM Reply
sorry. you said anderson lake- i assumed in CA.
Old    tribal            05-12-2003, 10:14 AM Reply
Rule 2000gph pump and yes I stand on the sac before to try and get all the air out and after the pump is on to try and prime.Yeh it's anderson lake in Can. and it's pretty cold right now.Was waking yesterday water was around 50.
