Im sure its not the bag. I filled the bag with water and held it up to see if it leaked and it did not. I also filled up the bag while on the trailer, pulled the boat out, and I could see water pouring out the back where the ballast hoses are connected. I havent been able to check for a cracked valve, I was hoping to not have to take too much apart. The manual valve is working as I mentioned above as my band-aid. Pat, would that valve you mentioned be towards the front or rear of the boat in relation to the pump itself?
