FOR THOSE WITH AN EXTRA $200 (199) LAYING AROUND.. PERFECT PASS HAS A COOL NEW UPGRADE TO A MULTI - LINE DISPLAY(SEE THE NEW 06 BOATS) AND FIRMWARE CHIP UPGRADE . CHIP ONLY IS 70 BUCK.. BUT THE 199 GIVES YOU THE MOST UP TO DATE PP THERE IS. STORES NAMES AND SPEEDS.. HAS BOTH SPEED BASED (WAKEBOARD PRO) AND RPM BASED(SKI MODE) THE NEW THING IS "SKIER MODE" WHICH IS rpm BASED SPEED MODE.. IE CAN SET IT FOR 30, 32, 34, 36.. AND IT USES THE RPM MODE TO KEEP SPEED.. STILL NEEDS TO BE CALIBRATED W/ GPS . BUT ONCE SET.. IT'S GOOD TO GO. CALL PERFECT PASS AND ORDER - EASY INSTALL TOOK 1/2 HR.. AND THE MULTI LINE DISPLAY(SEE WEBSITE) IS WAY COOL CAN SEE SPEED, RPM, SET POINT SPEED AND RIDER NAME ALL ON SAME DISPLAY - AND THE NEW SKIER MODE IS WAY COOL - NOT TOURNAMENT BUT CLOSE.. GOOD ENUF FOR RECREATIONAL PULLS. ON THAT NOTE.. FOR THOSE THAT HAVE "WAKEBOARD CRUISE" ON THEIR MOOMBA BOAT( ALREADY HAVE THE SERVO AND MASTER MODULE - BUT NO DISPLAY.. AND WANT TO UPGRADE TO WAKEBOARD PRO (OLD CHIP AND SINGLE LINE DISPLAY - BETTER THAN CRUISE - NOT AS GOOD AS NEW DISPLAY - BUT CHEAPER ALTERNATIVE - I HAVE A MOOMBA WHITE SINGLE LINE DISPLAY AND OLD CHIP WITH CHIP REMOVAL TOOL EASY TO DO IN 1/2 HR .. FIRST 75 BUCK TAKES IT.. REMINDER -- YOU NEED TO ALREADY HAVE MASTER MODULE(UNDER DASH) AND SERVO MOTOR (ATTACHED TO THROTTLE) ALSO THIS WOULD WORK FOR THOSE WITH OLD STANDARD PP DISPLAY (NO MOOMBA LOGO - THAT WANT TO UPGRADE DISPLAY )
