Old     (kyle_m)      Join Date: Aug 2007       09-04-2008, 10:35 PM Reply
been tryin alot of em and can get the rotation every time but i got a proble of turning like halfway to a tantrum to revert i dunno if its my backhand isnt coming off the handle when its supposed to it just feel so unatural but its whatev...
delta was epik today
and anyone got sum suggestions on the tantrum
Old     (wvboard)      Join Date: Jul 2008       09-05-2008, 3:57 AM Reply
Are you pulling the handle? If so it will cause you to rotate. Your arm should be fully extended for a tantrum. It should be pulled in close to your body for a tantrum to blind.
Old     (ironj32)      Join Date: Jan 2007       09-05-2008, 4:57 AM Reply
i had the exact same problem. for me, it wasn't a problem of pulling on the handle...i was turning my head to try and spot the landing. what finally got me over the hump was basically not using my head at all...almost concentrated on keeping my chin pointing down. i also concentrated on taking my rear hand off of the handle about 5 - 10 ft out from the wake. good luck!
Old     (airjordan175)      Join Date: Feb 2008       09-05-2008, 2:56 PM Reply
square up with the boat at the wake more
Old     (jarrod)      Join Date: May 2003       09-05-2008, 3:38 PM Reply
I you are spinning, you're either turning your head, or pulling the handle to the front of your body, or both.
Old     (dirwoody)      Join Date: Apr 2003       09-05-2008, 7:25 PM Reply
I had the same problem with landing mine, and just finally got it dialed in. For me, it's all about squaring up to the wake, if I don't do it right, I'm in the same position as you, but when I get the cut right, it's butter
Old     (wakemandan)      Join Date: Feb 2003       09-05-2008, 9:48 PM Reply
damnit marriot, where was my invite. Take me out and i'll show you how they're done.
