Old     (patrick)      Join Date: Apr 2003       05-13-2004, 10:22 AM Reply
Has anyone had any difficulties in doing so, I removed one side very easy, the other side would not budge and trying to move it slightly looked like it would easily damage the transom before coming undone. '03 VLX...
Old     (jnewcom)      Join Date: Mar 2003       05-13-2004, 11:06 AM Reply
mine comes off fine. I take it off whenever i clean it up real good, 03 vlx here too. Mine just has a pin in each side that u take out and it comes off. Are u having trouble wiuth the pin or something else?
Old     (jklein)      Join Date: May 2001       05-13-2004, 11:22 AM Reply
I know on mine that you need to lift it straight off on both sides at the same time otherwise it gets jammed. Sometimes I can do it myself and sometimes it takes two people, one on each side. I think it depends on expansion / contraction with the weather or amount of moisture in my swimstep.
Old     (mcfatty)      Join Date: Apr 2003       05-13-2004, 11:47 AM Reply
Yeah I have to take mine off everytime to put it in the garage. It has to be level or it gets stuck.
Old     (mississippireb)      Join Date: Aug 2003       05-13-2004, 1:41 PM Reply
Put some grease on your the bracket where the platform slides down. Makes it a lot easier.
Daniel
Old     (puckinshat)      Join Date: Sep 2003       05-13-2004, 2:39 PM Reply
A rubber mallet always helps too!
Old     (stevem)      Join Date: May 2002       05-13-2004, 5:41 PM Reply
I have an '03 VLX and the first 5-6 times it was miserable to install/remove. It gets easier over time. Not sure if it because you just get the hang of it, or it just fits better. Probably both.
Old     (patrick)      Join Date: Apr 2003       05-14-2004, 10:23 AM Reply
No problems with the pins, I've tried w/ 2 people lifting straight up, no luck and I stopped trying since the mount attached to the transom was moving about 1/8 of an inch which caused some worry. Maybe the rubber mallet and grease is the next thing to try.
