Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 10, 2008
Old     (goinboardn)      Join Date: Feb 2005       06-25-2008, 9:59 PM Reply
I have a 1998 Sky Supreme with a Merc 350 EFI. I have a problem when the boat is cold it bogs down and only goes a few miles per hour and i have to play with the throttle to keep it from dying. Once it warms up after 5 or so minutes of putting around it seems fine. What could it be? where would you start? fuel filter, plugs, O2 sensor (if they exist on the boat) any tips would be appreciated.
Old     (norcalmalibu)      Join Date: Jun 2004       06-25-2008, 10:51 PM Reply
when was the last time you cleaned the metal air intake?
Doe the Idle surge or just start to fade then die?
Old     (goinboardn)      Join Date: Feb 2005       06-25-2008, 11:04 PM Reply
-Probably a couple years ago when the engine was replaced
-It surges
Old     (peter_c)      Join Date: Sep 2001       06-25-2008, 11:14 PM Reply
Fuel filter should be replaced once a year. Fuel pump, coolant temp sensor aka ECT, throttle position sensor aka TPS, along with other sensors and simple things that can be hard to diagnose like bad gas.
Old     (goinboardn)      Join Date: Feb 2005       06-26-2008, 8:38 AM Reply
Are you saying the fuel filter is suspect or is that a general statement?
Old     (norcalmalibu)      Join Date: Jun 2004       06-26-2008, 8:55 AM Reply
Well depending on the boat it could have two fuel filters. You will have a fuel/water separator then sometimes another one on the feed line out of the tank.
The sensors Peter is referring to also can be the culprit. TPS, and Idle air are the ones I would check first but you need a voltage tester. (a cheap one from a auto parts store will work)
The problem now is trying to figure out what the correct sweep and settings for these two parts, I'd suggest looking for a shop manual on that motor.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-26-2008, 9:02 AM Reply
Fuel filter: if you didn't replace it last yr, its suspect. replace it now just to be safe.
Old     (mikeski)      Join Date: Aug 2003       06-26-2008, 12:16 PM Reply
Choke?
Old     (trace)      Join Date: Feb 2002       06-26-2008, 12:32 PM Reply
I thought choke too, but he said it's EFI.
Old     (goinboardn)      Join Date: Feb 2005       07-02-2008, 10:54 PM Reply
New cap, rotor and plugs and it runs like a charm again. The inside of the cap was in rough shape, so i can only assume that was the failure point.
