Old     (dreamer)      Join Date: Nov 2008       05-18-2009, 8:03 PM Reply
If you only use your boat on weekends do you turn your batteries off during the week? Would you loose the saved pull speeds on Perfectpass with the battery turned off?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       05-19-2009, 4:52 AM Reply
just buy a trickle charger.
Old     (chadgreg)      Join Date: Feb 2008       05-19-2009, 8:30 AM Reply
Your info will stay in your PP. At least it does in mine (Wakeboard Pro edition)
Old     (dhcomp)      Join Date: Jun 2003       05-19-2009, 9:02 AM Reply
If you use it one a month or so, you should be fine. Leave it turned on. If its going to be longer than that, you can disconnect if you want. Really though, you should be able to go months on a good battery connected, as long as you don't have any wierd current draws
Old     (tomfish)      Join Date: Apr 2003       05-19-2009, 10:06 AM Reply
If you have a stereo disconnect it. The memory and clock alone on the stereo will kill your battery in only a few days.
Old     (dhcomp)      Join Date: Jun 2003       05-19-2009, 12:11 PM Reply
Memory and clock will kill your battery in a few days? Are you kidding? If that is true on your boat, you need a new battery, or have somethign hooked up wrong. Your amps may not be turning off or something.
A boat battery, stereo or not, should easily be able to go 6mo without use and still start up fine
Old     (gotsumgas)      Join Date: Jul 2008       05-19-2009, 2:31 PM Reply
memory on your stereo and clock will not kill you battery in a few days. Anyone that thinks that is the problem better look for something else thats eating up current draw. My 22ssv has a bat switch that cuts the engine and major engine related functions but keeps current to the rest of the boat. I left that connection in place for the entire winter and had no problem in the spring.
