Old     (ddean)      Join Date: Dec 2006       10-23-2013, 7:07 AM Reply
Dinged the original and figured this was a perfect time to upgrade? Your guidance on how we get a bit more out of the hole when weighted?
Old     (EricU)      Join Date: May 2013       10-23-2013, 8:43 AM Reply
Just call Acme directly and they will help you pick the right prop, then ping Chpthril to order it
I am still amazed at the great personal service that Acme provides considering the volume of business they do
Old     (spencerwm)      Join Date: Feb 2009       10-23-2013, 8:45 AM Reply
Daryn,
What motor are you running and where are you located? What specific prop are you coming from?
Thanks,
Spence
Old     (KyleCloss)      Join Date: Oct 2013       10-23-2013, 9:12 AM Reply
Daryn posted on my behalf while I was setting up my login. It is an '04 Xstar with the 350hp MCX motor. I am located in Dallas, TX and the boat has the factory prop today.
Old     (spencerwm)      Join Date: Feb 2009       10-23-2013, 9:54 AM Reply
Kyle,
I would check out the Acme 1285 or the OJ 470. You will get a lot better hole shot from either while loaded down. Your top end will decrease but the low end performance will be worth it.
Thanks,
Spence
Old     (KyleCloss)      Join Date: Oct 2013       10-23-2013, 9:27 PM Reply
Thanks for the recommendations.
Kyle
Old     (PotatoShack)      Join Date: Aug 2013       10-24-2013, 3:41 AM Reply
I have a 5 blade prop ill let go for $300 I only used it two or three times.
Old     (PotatoShack)      Join Date: Aug 2013       10-24-2013, 5:56 AM Reply
Old     (snork)      Join Date: Jun 2007       10-24-2013, 7:20 AM Reply
can't use that 5 blade on a Mastercraft XStar it needs to be splined 1 1/8
