What is the wattage of your head unit. If you have one thats like 40x4 or 50x4, with 6.5's, you shouldn't need an amp. your head unit should push enough to give off really good sound. Subs do sound better with an amp, even if it's a 100-300 watter. You can always remove the amp and sub when your ready to get rid of the boat. check your head unit out first and if your head unit doesn't have rca output jacks(red/white connections on the back), you might consider getting a high powered head unit or you can get an adjustable line level converter(this allows you to hook up an amp to a factory head unit). hope this helps- good luck
