Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 04, 2006
Old    chachi            07-20-2006, 12:40 PM Reply
most of the time I cut hard away from the wake then cut back really hard and i can a air and clear w2w, but other times i feel that I cut way out and when cutting back the rope tension get loose or and rope not as tight, iam NOT using a non streach wakeboard rope, will it help that much
can someone give me some tips
Old     (99xstar)      Join Date: Aug 2005       07-20-2006, 12:43 PM Reply
When you cut out, flatten the board and ride with the boat before you cut back in. Don't cut out and cut right back in. Make sure you have some hang out time in between cutting out and cutting in.
Old    walt            07-20-2006, 12:46 PM Reply
Cut out and stop for a second. Then start Your cut slowly and progressively cut harder as You approach the wake.
It sounds like You are clearing the wake with speed and not line tension.
And yes You should buy a proper rope and handle.
Old    walt            07-20-2006, 12:47 PM Reply
http://www.wakeworld.com/Tricklist/TrickTip009.asp
Old     (extremeisaac)      Join Date: Aug 2005       07-20-2006, 12:50 PM Reply
welcome to the wonderful world of progressive edging
Old     (andy_nintzel)      Join Date: Sep 2004 Location: Minnesnowda       07-20-2006, 1:11 PM Reply
progressive edge.
Old     (mobv)      Join Date: Jun 2002       07-20-2006, 1:21 PM Reply
Non- stretch rope will make a big difference.
Old     (greatdane)      Join Date: Feb 2001       07-20-2006, 1:53 PM Reply
"cut hard away from the wake then cut back really hard"
Sounds like bad technique.
Old     (jarrod)      Join Date: May 2003       07-20-2006, 2:03 PM Reply
Anytime you cut hard enough increase your board board speed past that of the boat, and then back off, you create slack. If you want the rope tight, use a progressive edge and sustain a hard cut up the wake. If you want a softer line, come in faster and lighten up a little before you pop.
Old     (jarrod)      Join Date: May 2003       07-20-2006, 2:04 PM Reply
"It sounds like You are clearing the wake with speed and not line tension."
Amen....a common problem and a tough habit to break.
Old     (just_board)      Join Date: Jul 2005       07-20-2006, 9:35 PM Reply
chachi, i was kind of a disbeliever in non-stretch rope and i had always just used my ski rope until i actually went out and tried a non stretch rope and lemme tell ya, it makes a HELL of a difference, it's like night and day, and i don't feel like i'm exaggerating, but also, you have to have your progressive edge down number one, before you even try any trick. it's the very first step of becoming a "wakeboarder"
