Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2004
Old     (braap)      Join Date: Mar 2004       08-06-2004, 2:27 PM Reply
whats easier to learn, ts 360 or a hs 360? thanks again guys. I can land a hs 360 good, but can't hold onto the rope, but i can hold on to the rope with my ts but crash hard. any pointers?
Old     (antbug)      Join Date: Jul 2004       08-06-2004, 2:31 PM Reply
ts fs is easier due to the spin. The boat wants to pull you that way. keep trying
Old     (dakid)      Join Date: Feb 2001       08-06-2004, 2:35 PM Reply
these tips work well for both hs and ts 3s.
wait until you're at the peak of your jump before you pull on the handle to initiate your spin. concentrate on the handle pull and the handle pass. the rotation will happen, don't worry about that.
an easier tip for ts3 is at the peak of your jump, do a ts180. do that a couple times. then, do the same thing, but before you land, pull on the handle a bit more for the remaining 180, and voila - ts3!
either way, keep the handle close to you...it's much harder to pull and pass if your arms are out.
Old     (malibuboarder75)      Join Date: Jan 2004       08-06-2004, 4:32 PM Reply
the ts fs is easier to spin but a little more difficult to land at first. A lot of wakeboarders neglect ts and suck at ts edgins so the ts 3 is difficult. The hs 3 was easier to land, i got it on my 8th attempt although i think the hs 3 is a little harder to spin and get proper handle passing.
