I need some help on identifying a trick for an INT run.In the novice division you have to name your wildcard trick, so my daughter needs to know exactly what it is to get the points. Cut out HS. Then she looks like she is going to do a powerslide, but instead of a powerslide she passes the handle behind her back and spins all the way around. Is that a blind surface 180, or is it called something else?
