Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through January 14, 2005
Old    tyerone44            12-29-2004, 12:29 PM Reply
It sounds like the sond is coming from the prop. I have a 1990 prostar 190. There is a knocking sound down by the prop area when I put my boat into gear. It is extreamlly bad if I put it into Reverse. I never use to hear this sound. I have looked at the prop there does not seem to be anything wrong with it except a little ding in all 3 blades from a stump. The mark is probally no bigger than a pencil led tip. So I don't think that would be it. Can anyone help me. My belt seems to be squicking quite a bit to but only when it is in Neutral or very very slow. Thnks for the help.
Old     (jbenbri)      Join Date: Jun 2004       12-29-2004, 1:01 PM Reply
Check your strut bearings. Located inside strut, copper housing with rubber inside. Usually two pieces(at least that is how the ones I replaced were), one at top and one at bottom. Once they wear out, your shaft starts rubbing against strut ( metal to metal )and can cause some noise. Mine were bad and would hear loud "pop" evry now and then. You can usually tell by looking at them if they are worn evenly, if they are worn unevenly it could be an alignment problem. You will have to remove prop, and shaft to replace and can correct alignment problem when putting back together. www.skidim.com Call Vince or Richard, they sell bearings and can walk you through it. They also might be aware of other causes, very helpful guys. It is not a big deal provided you have right tools.
