I worked in a shop that repairs alternators and starters through college and replaced repaired 100's of alternators. Never saw a bent rotor. The rotor shaft is very short, supported on both ends with bearings. No way to bend it in the boat. I saw numerous times where bearings fail and allow the rotor to rub inside the alternator against the stator causing the alternator to be hard to turn and destroy the rotor and stator. Either alignment, rust, tight bearings, or over tight belt is causing the problem. When you have the belts off does the alternator spin freely? The water circulation pump (top pulley)? Are the grooves clean on all of the pullys? (Message edited by mobv on August 04, 2008)
