Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 06, 2007
Old     (chris_b)      Join Date: Feb 2007       07-17-2007, 10:58 AM Reply
What would cause my volt meter to read only 10 volts? I did not notice what it read before the stereo got hooked up back in the spring. The amp is grounded to one of the batteries, would this cause it to only read 10 volts?
Old     (jayc)      Join Date: Sep 2002       07-17-2007, 11:57 AM Reply
Check you voltage with a decent multimeter.
My guage under reads by a couple of volts and my mates in his seray over reads by a couple.
Old     (peter_c)      Join Date: Sep 2001       07-17-2007, 4:29 PM Reply
It could very well be reading 10 volts, or it may not be reading the actual voltage. Either way start with a volt/ohm meter and test the wiring circuit at the gauge, and go from there. Often times what happens is the wire going to the dash and accessories is too small, and the voltage drops. Adding in either a larger size wire or a relay triggered how ever you want.
