Old    jetpilot313            06-09-2004, 8:26 PM Reply
is it worth paying the extra money for this option, exactly what does it do, increase engine life or prevent corrosion?
Old     (wake_upppp)      Join Date: Nov 2003       06-09-2004, 8:30 PM Reply
If the boat was going to be run in salt water all the time, you would need it, otherwise not really needed.
Old    jetpilot313            06-09-2004, 8:32 PM Reply
would it extend the life of engine or prevent problems
Old     (wakescene)      Join Date: Feb 2001       06-09-2004, 8:34 PM Reply
I would say so regardless...
More controlled condictions within the motor, a must for saltwater driving, less chance of debris getting caught in the block and causing a blockage, easier maintenance, more predictable wear/failure/replacement of parts...better resale value!
just my $.02
KG
Old    jetpilot313            06-09-2004, 8:36 PM Reply
ithink its like 1300 does that sound right
Old     (xaggie)      Join Date: Nov 2002       06-10-2004, 12:28 AM Reply
We boat on fresh water 100% of the time and with the LQ-9 we had no option of a hot shower. Not like you need it much in Texas, but as stated before totaly not a thought unless you boat in salt/brackish stuff.
Old     (deepcove)      Join Date: Mar 2004       06-10-2004, 6:11 PM Reply
It will help prevent problems which will inevitably increase engine life. 1300 sounds about right. I have one installed on my 04 Mobius as I run exclusively in salt. I would also recomend you get a flush kit installed, about $65.00. This will help extend the life of your risers and manifolds providing you flush after each use.
