Bryce, I have a fuel injected Monsoon in a 2000 vlx and did something similar to Razzman's note. If you have the Indmar mechanic's book I think it tells you how to do this. I believe it says to use a bent up paper clip to "jump" two wires to disable the computer timing advance. Once you do this you put the timing gun on it, set your timing, kill the engine, pull the paper clip out and re-start...or something to that effect. I discovered that mine was off by close to 15 DEGREES because the Idiot before me had no idea how to set it. It made it run SOOOO much better (obviously, because the computer was having to compensate for the horrible manual timing).
