I have a 23LSV with dual batteries in the port v-drive locker with perko switch attached to the top corner of the locker/engine area divider. I want to move the batteries to the storage area behind the observer seat so I can fit bigger sacs in the lockers. My soundsystem is roughly 800W (on top of normal electronics). Both batteries are identical Diehard marine batteries. The soundsystem and electronics work great as is and it is unlikely that I will upgrade. I see two ways of doing this: 1. leave the perko where it is and run two large wires (one from each side of the perko) up to the observer storage area, connect one wire to battery 1 and one to battery 2 2. remove the perko, use a distribution block at that point, connect all wires to the distribution block, run one very large wire from the distribution block to the perko relocated in the observer storage area, connect one side of perko to battery 1 and one to battery 2 Are there any negatives associated with either choice? What size wire is recommended for either option? Is there a good online store or brand of wire that is best? Thanks for the help!
