I have a 2005 X-2 with the MCX motor, problem occurs while trying to engage forward/reverse gear and pick up throttle. I can engage both forward/reverse but then the engine won't pick up rpm's, it just stays at idle. At the same time the check engine prompt comes on and an alarm sounds. I've had a boat shop look at this, they figured it was the throttle actuator control, but after $950 worth of repair the same problem persists. Any ideas or help would be appreciated as they don't have any other ideas and now the boats been down for 6 weeks.
