I just bought a pair of 08 Ronix ONE bindings but they came without the screws...the ones to lock them to the board. Do someone know the characteristics of the screws so i can get them somewhere else? Thanx.
Talk to the shop/site/person you bought the boots from, they would be your best bet for getting the actual screws you need. Decreases the potential for problems with the wrong screws messing up the inserts on the board, among other things.
Well if you have a local shop I am sure they could sell you some replacement bolts, but otherwise the only other option I can think of would be to take your board down to the local hardware store and start trying bolts. I am not sure if they are metric or not.
I would suggest calling Ronix customer service. They will either hook you up with a set or else be able to tell you exactly what you need and where you can get it.
Actually, they're 'j-bars' designed to fit between the inner liner and outer shell. If you reach your hand down between them, you should feet the patch of velcro for these to attach. Only use them if you feel you need more heel lock-down.
