I am in the process of trying to change the shaft packing in the boat but ran into a road block. There is a stainless steel ring that does not allow the nut to slide far enough forward to get to the packing. It looks like it can be loosened by the set screws, but the shaft feels a little bigger which might not allow it to slide forward. The set screws are also stripped and very rusted which will take a little bit of work to get loose if required. Any advise?
