Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 01, 2007
Old     (chadly22)      Join Date: Apr 2007       04-09-2007, 11:26 PM Reply
Has anyone who runs in salt water tried installing a heater. I've heard lots of complaints from people about their heater cores leaking. I'm assuming this is from rust. Should I even bother with the project for salt water use?
Old     (deepcove)      Join Date: Mar 2004       04-09-2007, 11:47 PM Reply
I have a heater and run in salt water, I have not had any issues in 4 years.
Old     (chadly22)      Join Date: Apr 2007       04-10-2007, 12:16 AM Reply
Deepcove, Do you have a fresh water cooling system?
Old     (bob)      Join Date: Feb 2001       04-10-2007, 1:05 AM Reply
Had one for 3 years and it finally ate itself and I flush with salt away religiously.
Old     (jayc)      Join Date: Sep 2002       04-10-2007, 4:18 AM Reply
I ahve a heater in my current saltwater boat. 2 years now without issue.
eater cores are not that expensive so if you budget for replacing them every 4 years or so you should be ok.
Defo worth it though. Over here in the UK I use my heater pretty much any time the boat is out except on the warmest days.
Old     (peter_c)      Join Date: Sep 2001       04-10-2007, 8:20 AM Reply
The core is only around $30, so who cares? You burn more than that in fuel, in a few hours running the boat.
Old     (chadly22)      Join Date: Apr 2007       04-10-2007, 9:34 AM Reply
$30 is no issue. I thought it would be closer to $300. The entire kit from heatercraft is around $450 so I figured the heater core would be the most prominent part. Peter, which cores are $30?Has anyone tried using an old heater core from a car or truck?
Old     (deepcove)      Join Date: Mar 2004       04-10-2007, 6:14 PM Reply
Chad
Yes i have a closed cooling system
Old     (greg2)      Join Date: May 2002       04-10-2007, 8:42 PM Reply
A buddy of mine's heater core froze and busted over the winter. We matched one up at the auto parts store and I believe it was for a 64 Ford Falcon. We put it in and it's worked great so far. We did have to pad up the sides a little.
