Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 20, 2006
Old     (john_prine)      Join Date: Nov 2006       11-30-2006, 12:26 AM Reply
About to order a 2007 Malibu 23lsv wakesetter. We are getting the boat with-
Free floating wedge
8.1 450hp indmar vortec
Fiberglass swim deck
bimini top
boat cover
carpet savers
docking lights
6 polk speks on tower with amp
8 polk speks in cabin/boat with amp
2 12s JL audio subs
72k OTD
Anybody else have 07 wakesetter with SOMETHING GOOD TO SAY
Old    kvanderg            11-30-2006, 6:08 AM Reply
Colby,
I am considering ordering a 2007 but am trying to line up a new old stock or low hour 2006 as I like the finishing on the 06's a little bit better. Either way... same mechanicals, hull and same great wake.
I currently have a 2005 23LSV and totally love the boat... as I have said in many posts... you will have to look long and hard to find a better all around boat than the 23LSV. Anyone who disagrees with that statement more than likely hasn't spent any real amount of time in, behind or around a 23LSV.
IMO the 8.1L isn't required in the vast majority of cases and will make it harder to sell or trade in down the road. There is a very low % of people that get the 8.1L in a new boat (cost, maintenance, gas); therefore, an even lower % of people will want it in a used boat as there is usually a cost driver to go used.
Only with 3 full ballast tanks, wedge down, and 8 people in the boat did my Hammer Head (400HP) struggle. In that case we just pulled up the wedge and filled the bow ballast tank and life was good again. Any way you slice it... it was a BIG silly wake with great shape, kick and transition. The 23LSV wake is almost impossible to screw up as far as weight placement.
Look at torque curves for the various motor options (340, 400, 450HP). Its more about low end torque than high end HP.
Other than that... order the 23LSV already
Old     (tings00)      Join Date: Aug 2005       11-30-2006, 7:34 AM Reply
whats a free floating wedge
Old     (kevin_lsv23)      Join Date: Oct 2006       11-30-2006, 8:15 AM Reply
It is the new manual wedge. It has two positions. Locked in the up (not in use), and loose (in use). It seems to work great.
Old     (wakesetterlsv)      Join Date: Oct 2005       11-30-2006, 8:42 AM Reply
I own a 06 23 wslsv and I agree with Kevin that the 8.1 is not necessary. I have the Monsoon 340 and once re proped its plenty of motor. I run on average 3000 lbs and 6 heads and it jumps out on the hole. Also you may want to consider the power wedge for its versatility and resale.
Old     (buguru)      Join Date: Feb 2006       11-30-2006, 9:20 AM Reply
John that sounds like a great price where you buying it from?
Old     (brd4fun)      Join Date: May 2002       11-30-2006, 10:23 AM Reply
I also have a 2006 LSV with a 8.1 and would not want it any other way. Is it needed probably not but I love having it.
It does not use much if any more gas than the last 5.7 340HP that I had.
I would go with the Power Wedge if you have the extra cash. It rocks.
You are going to love the boat.
Old     (jv210)      Join Date: Feb 2006       11-30-2006, 1:10 PM Reply
I got my 07 a couple of months ago and ordered with the 5.7, and it has plenty of power even with the boat loaded. with a better prop it would be even better. I would also recommend the power wedge, and IMO I think the docking light are a waste of money, the nose is so low in the water that the lights would do nothing
Old     (johnny_jr)      Join Date: Mar 2006       11-30-2006, 2:01 PM Reply
All I can say is go with all the options you can. I didn't and regret some of the decisions. From the list looks like you touched on some the ones I miss out on. Go with the 8.1L regardless of all the hype on it being too much, I already ran into a few times I wish I had more. Last think about the power wedge as well, that's one option I got and love, it really lets you refine your wake.
Old     (johnny_jr)      Join Date: Mar 2006       11-30-2006, 2:02 PM Reply
Last 10 cents, your OTD is inline with all the options you detailed, that boat is going to me sweet!
Old     (malibupilot)      Join Date: Nov 2005       11-30-2006, 4:07 PM Reply
Sounds like a sweet ride the way you have it. I've got a 06 247 with the 383.... seems like I always have more than enough power.... without mesing around with different props.
I have the manual wedge.... I'm not 100% sure, but I think that the power wedge may have a setting that makes wakesurfing a bit better than the manual wedge.
