I have a Tige V-drive and had the recreational PP on there for 4 years. It worked OK- some issued now and then, but for the most part if you place the paddle wheel properly it works fine. I moved up to the Wakeboard pro last year and am VERY happy. If you have the dough, I would go for it. Custom settings, it ALWAYS locks on - you can adjust for ballast, so it won't "hunt" for the speed and it also works at 10-11 MPH for surfing. Also if you ski, the pull is much more consistent- I found that the Rider's cruise would surge a lot, but on ski mode with Wakeboard pro, you go to the RPM mode and it locks on great. Bottom line is that both work well and take the idiot out of the driver- just get one or the other- your friends will thank you!!
