Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 19, 2006
Old     (jmunday)      Join Date: Mar 2006       05-11-2006, 9:41 AM Reply
I have a 1992 ski ray boat and all i wanted to get was a switch for my dash, because i have an extra slot with a dummy switch in it. so on good friday i went to sea ray and ordered one. they said that i would recive it in no time, then yesterday 05/10/06 they called me and said that they no longer carried that part? what the hell. does anybody know of a good place to get stock parts?
Old     (acurtis_ttu)      Join Date: May 2004       05-11-2006, 10:30 AM Reply
your boat is almost 15 years old, I would have been skeptical of someone telling me they had the oem part. Have you tried www.skidim.com A switch should be pretty easy to match up to OEM.
Old     (jmunday)      Join Date: Mar 2006       05-11-2006, 4:28 PM Reply
i appreciate it ill try that
Old     (nbeihl)      Join Date: Mar 2004       05-11-2006, 8:13 PM Reply
two thumbs up for skidim
Old     (rem_pss308)      Join Date: Mar 2004       05-12-2006, 12:35 AM Reply
ALso Westmarine.com has part like that.
Old     (yosquire)      Join Date: Jun 2005       05-12-2006, 8:39 AM Reply
Ski Ray bought the switch from someone. Look at a higher level.
www.mouser.com
www.digikey.com
www.alliedelc.com
Old     (boarditup)      Join Date: Jan 2004       05-12-2006, 10:39 AM Reply
If I recall correctly (and that was a long time ago), the Ski Ray used a standard Perko switch with a Sea Ray switch cover. You may want to see if you can remove the switch cover and see if there are pop-offs for the cover to actuate. You may find that a stardard marine grade switch may bolt into place with the existing switch cover to work it.
