Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through January 28, 2006
Old     (bkoz)      Join Date: Dec 2005       01-20-2006, 8:27 AM Reply
Hey all, I have a few ?’s regarding my stereo install. Im not doing anything fancy as I just bought the boat and have a family to take care of so im not able to spend a bunch of $$$ on a system but have managed to put together enough stuff to make something decent (I think?). Im just looking to be able to here good clean sound in and around the boat, could care less about hearing it while riding at this point. Heres what I have.
(2) Infinity 1240’s ( single voice coil) 300 watts rms ea
Audiobahn A2502DP
250watts rms X2 at 4 ohms 500X2 rms at 2 ohms 500X1 rms at 4 ohms mono and 1000x1 rms at 1 ohm mono
Id like to use this amp for the subs. Should I run one off each channel or bridge it and run them parallel? Or would I be better off just getting one sub that can handle the power my amp has instead?
(2) Audiobahn 6X9’s 100watts rms ea
(2) Boston Acutstic 6X9’s 60watts rms ea
Audiobahn A4004T
50X4 rms at 4 ohms 100X4 rms at 2 ohms and 200X2 rms at 2 ohms
Id like to use this amp for the 6X9’s. I was thinking of (if I can) using 2 channels at 50watts rms ea on the Bostons then bridging the other 2 channels to the Audiobahns for 100watts rms each at 2 ohms. Would this work?
I have a Sony CDX-7815X HU (23.2 watts rms X4)
It has 3 4V preouts including a sub out
I also have (4) Pioneer 6.5’s. Should I run these off the HU or would it even be worth it?
Thanks for any input or advise on any changes or how the best way to set this up would be and any opinions on how I could maybe make it better without spending a lot more $$$ as I just cant swing too much more at this point.
Old     (bkoz)      Join Date: Dec 2005       01-20-2006, 10:32 AM Reply
Oh forgot to mention, im running (2) Trojans for the stereo and a starting battary with a 4 possition perko switch. Is that enough?
