Jason that is definitely a sweet setup then
Are you using some type of bang line, because that prop looks dang close to your rail car (Is that what they are called?). Something like a plastic covered cable mounted from the bottom of the car to the bow eye with a hook, or even something above the water would work.
Edit: Personally I would plant some grass between those rocks. It would blend right in with the neighbors grass.
(Message edited by peter_c on July 13, 2006)
