Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 15, 2008
Old     (tj_in_kc)      Join Date: Jan 2008       10-05-2008, 7:41 PM Reply
So if I have a 2007 Malibu 320 LCR.
No heater or shower.
Does that mean my boat doesn't have a heat exchanger?
Seeing the note about inspecting the zinc anodes in the service manual, but it doesn't really talk much about them, other than i think they are located inside the heat exchanger.
i don't know if my boat has a heat exchanger.
Anyone else have a Malibu 320 LCR with no heater and no shower. Do you have a heat exchanger?
Old     (99_air_warrior)      Join Date: May 2008       10-05-2008, 8:05 PM Reply
It has a heat Exchanger for the drive units. like a car trans cooler uses air it just uses the water as a heat absorber to cool the trans. Joe
Old     (davomaddo)      Join Date: Feb 2003       10-05-2008, 9:36 PM Reply
What the manual is referring to is a system used in boats that go in salt water. It uses anti freeze to cool the motor. If you have a anti freeze tank in you engine compartment (a tank with green liquid), then you have a heat exchanger. If not, then no.
most wakeboard boats do not have heat exchangers.
Old     (mobv)      Join Date: Jun 2002       10-06-2008, 8:53 AM Reply
Most wakeboard boats have a heat exchanger for the transmission oil cooler.
