Finally completed, and tested my ballast system. To start with I used a 1.5” through the hull scoop. From that I put in a ball valve to be shut of in case of problems. ( I know the engine doesn’t have one, but I thought it might be needed. ) I used 1.5” pipe to a Tee that necks down to a threaded ¾” Nipple. From this I have a ¾” I.D. hose run to (2) two Jabsco Ballast Puppy Pumps 18220-1123.( These pumps have run dry protection, and ignition protection, and come with a switch ) One Pump supply’s My rear sac ( 900 lbs. ) The other pump supply’s The (2) two side sacs( 250 lbs each) and a front sac ( 550 lbs). From the pumps I used ¾” flexible PVC, it doesn’t collapse when draining. ( purchased from Lowe’s @ $27.00 for 50’) The 90’s and Tee’s for this pipe have a ½” I.D. which is the same as the I.D. of the pumps. My rear bag is enclosed in a compartment that I built, also serves as a sun deck. I added a overflow Flapper check valve, and a through the hull ( like the one used for the bilge) I have a ¾” ball valve at each bag. I also have a PVC check valve inserted into the other hole in each bag. ( Just in case I forget to turn it off in time) to replace the blue waterbed fitting, I used a 1” nipple. I had to use a blowdryer to warm the bag inlet to get it to fit. When not in use, the front bag is stored in the left front seat., and the side bags are stored in the side compartments. The Jabsco pumps drain the sacs of water and air, so they are nice and flat, and can be folded up with out having to bleed air out of them. The system works great. It takes just under 10 minutes to fill completely. It takes the same time to drain, when sitting. It takes about 11 minutes to drain when under way( on a plain ), due to the scoop, I am sure. I will try to add pictures when I can. I wanted to post this so hopefully it will help anyone who needs ideas, as I did. I received a lot of valuable information on here to complete my system. Thanks
