This is off their website (
http://www.optimabatteries.com) in the FAQS section:
17. When should I use a Deep Cycle OPTIMA as a Starting battery?
"Deep Cycle" batteries are designed for applications that require deep, repetitive amperage drain, like trolling motors, golf carts, and electric wheelchairs, or RV house power sources. However, there are other applications, called "Heavy Cycling" or "High Cycling", when a Deep Cycle OPTIMA can successfully replace a starting battery to provide longer life and better performance.
In heavy cycling or high cycling applications, a vehicle will pull unusually high amperage levels from the starting battery due to extra accessories or limited alternator capacity. Public safety professionals, such as police, fire, and ambulance fleet managers often find that traditional starting batteries cannot provide adequate life and performance due to heavy cycling. This is an excellent opportunity to provide your customer with longer life and better performance by using an OPTIMA Deep Cycle battery in this type of application.
In any vehicle or equipment that will use the battery only for Starting, Lighting, & Ignition requirements and has a properly working alternator, the OPTIMA Red Top Starting Battery will perform extremely well, often providing up to two to three times longer life than conventional batteries. If the vehicle has few or no after-market accessories and uses a stock or upgraded alternator, the OPTIMA Red Top Starting Battery is the appropriate choice.
Remember, it is possible for the customer to have a completely discharged Yellow Top OPTIMA that will not start their engine; the advantages of the Yellow Top are that it can accept a rapid recharge and it will recover from discharge many more times.
To provide the customer the best OPTIMA solution, it is, necessary to consider both the application and the charging system before recommending the correct OPTIMA. For example, if your customer has a Ford Expedition with an after-market alarm system, which OPTIMA would you recommend? If the customer drives the car every day, the Red Top would be the correct choice, since the amperage drain will be nominal and the battery would be recharged on a daily basis. However, if the customer stores the vehicle for a long period of time with the alarm system engaged, you should recommend the OPTIMA Yellow Top, since the amperage drain over several weeks would damage a Red Top and reduce its life.
