i think you have us a bit confused, a picture or drawing would make things much clearer. Im asuming that the relay is already wired to the switch and the pump, and so you'll need to connect a + wire from a constant 12v sorce with a fuse that corisponds with the draw from the pump, an extra spot on the factory fuse pannel or strait from the battery or distribution block would be where i suggest this wire will have to carry the load when runing the pump. A - wire will also have to be run to the relay. This is just to activate the relay, no load so it can be taped of another relay or fuse pannel. The switch will need a + wire coming in, once again no real load on this wire tap from the switch next to it. If you switch has a light then i will also need a - wire, tap from the switch next to it. The pump will need the - wire connected to a large - sorce, as it carries the load for the pump. Batterty distribution block or fuse pannel. With two pumps you'll have two relays, so the empty lead from the switch will go to one and the fill lead to the other. as for the silinoid it will need to be connected to the fill pumps + power wire. then the - side to a constant - sorce.
