Old     (rytug208)      Join Date: Apr 2009       04-18-2009, 10:58 PM Reply
Has anyone been successful at running wire through a extreme phat tower? I have tower speakers and would like to hear some ideas.
Old     (wakebrdjay)      Join Date: Apr 2008       04-19-2009, 6:19 AM Reply
Post a picture of the tower that might get you some help.
Old     (bbeach)      Join Date: Jul 2002       04-19-2009, 7:59 AM Reply
put a lite string through the speaker wire hole near where you are planning on mounting the speakers (plug other holes) and stick a vacuum down near the base where the wires will exit the tower. The vacuum will suck the string through - tie your wiring to the end and pull on through. WUALLA!
Old     (mobv)      Join Date: Jun 2002       04-19-2009, 10:09 AM Reply
The vacuum works, I used fising line.
Old     (oddos2525)      Join Date: Mar 2008       04-22-2009, 5:30 PM Reply
dental floss and a vacuum. like a charm
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-23-2009, 8:04 AM Reply
IF the tubing is a single piece! you may have to drill out and re-enter the tower where joints in the tower and hinges are. IIRC that tower has several bends and welds on sides.
Old     (flackpack)      Join Date: Feb 2004       04-23-2009, 12:31 PM Reply
I have a Phat Tower, and the Vacuum works well. You also have to run the wires into and then out and back into the different sections. My wires exit the top of the deck near the front of the left leg and enter about 2" up on the bottom of the leg. They exit near the top of that section and re-enter slightly above the joint. Then they run internally all the way up to the top cross bar and exit at the connection points where my speakers are mounted. Where the wires exit and re-enter the tubing, I have about a 3" run of exposed wires covered by plastic wire loom.
(Message edited by flackpack on April 23, 2009)
