Well, not wanting to give out incorrect information I just measured 4 towers, model years 1999, 2000, 2001 and 2004 (installed on X-Star and X2). EVERY single one of them measures 1.875 to 1.900 (5 random measurements per tower). Now to put that into perspective the difference between the published specs of 1-7/8" and a measured 1.900" is .025"...put in everyday terms that is the thickness of 5 sheets of copier paper (yes, I measured them). Before anyone asks I used a Mitutoyo 6” dial caliper that was certified accurate last year (10/03). The difference in tubing diameter can be traced to the tubing itself…this isn’t mil-spec stuff here, combine that with a product that has been clear anodized, bent and welded…and you get some variance that should easily fall within the specs of any aftermarket supplier.
