Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (dave27)      Join Date: May 2005       07-31-2008, 8:31 AM Reply
Anyone have pictures of where this thing is. Or instructions. I quickly looked at the engine and didn't see where the impeller should be. I thought it would be where the water pump is on a normal engine. I would think it would be really obvious!
Old     (nsolis220)      Join Date: May 2007       07-31-2008, 8:48 AM Reply
if its a black scorpian stand on the swim platform facing the boat its in the bottom left corner of the engine. Its super tight in there and hard to get to! Goodluck
Old     (hamkj)      Join Date: Apr 2002       07-31-2008, 9:01 AM Reply
Hey Dave... I just called a tech at Supreme and asked for detailed instructions on how to get at mine since it looks like it will be a bbbbeeeeooooottttcccchhhh....
If you go into the observers side v-drive hatch... and remove the side panel... you will be able to find the impeller housing at the back of the boat near the cool fuel unit... just follow your belt... not that hard to find.
Yours will be similar.
1. Take serpentine belt off.
2. Use 9/16 socket with extension and there are 2 bolts holding the impeller housing on the engine... close to each other... one above the other... remove bolts.
3. Now that the housing is loose, remove the two hoses.
4. You should now be able to remove the impeller housing from the back side of the exhaust.
Before removing the impeller from the housing, make note of which way the splines are leaning.
Now that you have the impeller housing in your hands... check for any debris, scraped, grooves etc...
Assuming the housing is fine, take some grease and lube it up! Install the new impeller with the splines in the correct direction... and re-install the housing.
Hope that helps.
Old     (hatepain)      Join Date: Aug 2006       07-31-2008, 9:16 AM Reply
Ah Ha, so you don't have a 2009 Wakestar 21 VAH "V-Drive Variable Adjustable Hull"
Old     (treycleaton)      Join Date: Mar 2005       07-31-2008, 9:28 AM Reply
^^^^just did mine, exactly. I used vaseline in the housing
Old     (hamkj)      Join Date: Apr 2002       07-31-2008, 11:56 AM Reply
HatePain... due to economy slow down... will be bringing that out in 2010. It will be the Vancouver 2010 Winter Olympic Edition.
Old     (bftskir)      Join Date: Jan 2004       07-31-2008, 4:07 PM Reply
it does not matter which way the splines are, they will be turning only oneway and immediately corrects itself upon running it. no worries.
Old     (bftskir)      Join Date: Jan 2004       07-31-2008, 4:08 PM Reply
use soap not grease to slide it in
