Old     (schuey)      Join Date: Apr 2005       07-24-2011, 3:24 PM Reply
I have a couple of sumo sacs but am looking at getting some fly high pro x series sacs, will my Straight Line Uber pump be compatible? I have the 3 adapators that came with the pump when i bought it back in 2008, but just wanted to check which adapator it is I would need to check I have it? Cos it looks like a much narrower filling valve on Fly high sacs than on my old old sumo sacs which had a very wide valve.
Thanks
Old     (chexi)      Join Date: Jul 2009       07-25-2011, 8:08 PM Reply
Yes. There is an adapter with a straightline quick connect on 1 end and a Fly-High male thread on the other. I use my Uber pump to fill my Fly High sacs. It sucks though, because unless you leave the sacs a little less than full, you will spill some water when unscrewing the pump and then screwing on the Fly High plug.
Old     (spencerwm)      Join Date: Feb 2009       07-26-2011, 7:35 AM Reply
If you bought the Uber pump in 2008 you probably received the Launch Pad Female Link to 3/4" GHT Adapter (Pictured Below). Now all you need is the Fly High Standard Pump Quick Twist Connector W732 fitting (Pictured Below). Screw that onto the bottom so that you don't have the same issues that Schuey is having.
Old     (chexi)      Join Date: Jul 2009       07-26-2011, 11:46 AM Reply
I did not realize that this Fly High part existed. That is really nice. If I weren't going to plumb everything in, I'd buy one for sure.
