Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 10, 2008
Old     (1gixxer)      Join Date: Aug 2006       07-04-2008, 9:42 AM Reply
I put a new prop on my Supra. It is bigger than the stock one. It is hitting the trailer by what looks like a 1/4". So the way I see it is I can ether put spacer under the wood runners to make the boat sit higher. Or I can cut, lower and re weld the trailer where the prop is. Has anyone else run into this problem? What are some of your thoughts?
Thanks
Old     (otown_dave)      Join Date: Dec 2007       07-04-2008, 10:13 AM Reply
My father-in-law had a problem with his on the Nautique, Only his frame rails had spread enough to hit. We used a come along to pull the rails closer together making the hull sit higher & a whack on the cross member to set it lower & hold the rails where we pulled them. I assume on the older nautique trailer there was not as much bracing like the supra .
Old     (chpthril)      Join Date: Oct 2007       07-05-2008, 7:52 AM Reply
Before you go modifying the trailer, you might want to revisit your prop selection.
Old     (wakemikey)      Join Date: Mar 2008       07-05-2008, 8:19 AM Reply
ya I'm no expert but if it's too big it probably is spinning too close to the boat hull?
Old     (tdiggity)      Join Date: Dec 2006       07-05-2008, 9:25 AM Reply
agree with mikey on that
Old     (882001)      Join Date: Nov 2003       07-05-2008, 10:24 AM Reply
same thing happened on my boat. i moved the bunks up.
Old     (deltawake)      Join Date: Sep 2004       07-05-2008, 10:34 AM Reply
I had a similar problem with a DHM Trailer when I put an Acme 1235 on our WS VLX. DHM was able to put a slight bend in the cage that protects the prop and rudder. They did it when I had the trailer in for some warranty work, and didn't charge. DHM is a class act from what I can tell with my dealings with them.
Old     (mobv)      Join Date: Jun 2002       07-05-2008, 1:59 PM Reply
If your prop is that much larger you are going to kill the hole-shot.
Old     (mikeski)      Join Date: Aug 2003       07-06-2008, 12:21 PM Reply
Two easy options for a quick fix.
1. Bend the prop guard down if you can (I did it on my Nautique 211's prop guard to fit the 1234)
2. Install 1/2" of galvanized square washers between the trailer and bunk mounts to raise the whole boat up 1/2".
George, that prop works great on loaded boats, it drops pitch and gains blade. Net result is like running wide low profile tires on a car; better traction with lower gearing. Big holeshot gains.
(Message edited by mikeski on July 06, 2008)
