Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 10, 2008
Old     (wayz)      Join Date: Jun 2005       07-03-2008, 10:29 AM Reply
Does anyone have any experience what the little red V-Drive light indicates? It says "do not run v-drive if the light is on above 1200rpm". My light is on or flickering at sometimes. What should I check? My boat seems to be running fine, but that flickering light is bothering me.
Old     (sidekicknicholas)      Join Date: Mar 2007       07-03-2008, 10:46 AM Reply
ours stays off most of the time, but once in a while we get the flickering too... we usually ignor, if it stays on then maybe there is cause for concern....
i would check fluids if everything looks good you should be fine
Old     (ridininmd)      Join Date: Jun 2006       07-03-2008, 10:49 AM Reply
check the fluid level in the vdrive. If it's flickering above 1200 you're probably low.
Old     (hatepain)      Join Date: Aug 2006       07-03-2008, 10:50 AM Reply
Check your Vdirves oil with the dipstick right on top of it. That would scare the hell outta me.
Old     (plhorn)      Join Date: Dec 2005       07-03-2008, 11:00 AM Reply
If you have a leaky oil line in the v drive the v drive oil circulating pump could be sucking air so the oil will heat up and eventually fry your v drive or the pump.
Check the hoses on the v-drive for leaks.
Old     (trace)      Join Date: Feb 2002       07-03-2008, 11:37 AM Reply
It is probably the sensor going out. I've replaced mine twice so far in 7 years with my current boat.
Old     (wayz)      Join Date: Jun 2005       07-03-2008, 11:40 AM Reply
Trace, what sensor are you talking about? Thanks in advance.
Old     (trace)      Join Date: Feb 2002       07-03-2008, 12:30 PM Reply
On a Walter V-drive, one of these should be screwed into the port side of the V-drive unit.
Old     (meathead65)      Join Date: Sep 2006       07-03-2008, 12:56 PM Reply
Is it only flickering below 1200 RPM's??? If so, it is normal. If it remains on after you exceed 1200, you need to research the cause.
Old     (whistler)      Join Date: Jun 2008       07-03-2008, 1:00 PM Reply
Agree with Meathead, mine is always on when slow idling.
Old     (flux)      Join Date: Jun 2003       07-03-2008, 1:26 PM Reply
SAE 30, should not take that much really. Mine has a slow leak so I have to top it off twice a summer.
Check the level before you replace the sensor.
Old     (mobv)      Join Date: Jun 2002       07-03-2008, 7:01 PM Reply
I had a broken wire (connector) that caused intermitent problems before it broke all the way off.
Old     (ghostrider_2)      Join Date: Aug 2004       07-03-2008, 8:18 PM Reply
If its below 1200 then its normal especially for Sangers (always on in neutral)
