Does anyone have any experience what the little red V-Drive light indicates? It says "do not run v-drive if the light is on above 1200rpm". My light is on or flickering at sometimes. What should I check? My boat seems to be running fine, but that flickering light is bothering me.
ours stays off most of the time, but once in a while we get the flickering too... we usually ignor, if it stays on then maybe there is cause for concern....
i would check fluids if everything looks good you should be fine
If you have a leaky oil line in the v drive the v drive oil circulating pump could be sucking air so the oil will heat up and eventually fry your v drive or the pump. Check the hoses on the v-drive for leaks.
