09-22-2005, 5:20 PM
Does any one have them? I saw that Malibu is offering heated drivers seat. I was thinking about adding them to my boat. I was wondering what kind of voltage/amp draw they took. And I was wondering if it dryes out the vynil.
09-22-2005, 5:27 PM
They have been doing them on cars for years so I would think they have it dialed in as far as voltage/amp. That Vinyl is made for the sun so I wouldnt think it should hurt. G for it. It would be nice after riding in cold water and then being able to drive and stay toasty.
09-22-2005, 5:43 PM
putting heaters in the passenger seats would be sweet
09-22-2005, 7:56 PM
Heated seats are offered in all new and 05 Bu's. The heater coil is located in the bottom of the seat not in the lumbar area as indicated by the picture in the sales brochure. I believe the warmer functions off of the heat exchanger for the main heater. Sometimes when we are idling into the marina in Disco Bay it cools off a bit, but if you keep your RPMS above 1000 (like when your riding) it works very well. It's great for early morning rides. I got a dry suit and my wife got the seat warmer.
09-22-2005, 8:26 PM
Conway's boat has one. DOPE! Just the driver seat I believe.
09-22-2005, 8:44 PM
My suv has them and I would never buy another car/truck without it. However, hope to god they never go out on you after the warranty runs out. Mucho expensive to have replaced. Have to take the entire skin off the seat, install new elements and put skin back on. Mine went out in the truck and would have cost me 1000 bucks.
09-22-2005, 11:18 PM
I've got the heated driver's seat on the new Malibu and it's fantastico! I've used it a few times on cool summer mornings, but haven't had a chance to use it through the winter yet.
09-23-2005, 6:14 AM
I have installed several aftermarket heated seat systems in cars/trucks element gets mounted into foam rightunder seat cover very simple to wire and draws3-4 amps per seat(two elements). Be cautious though they get very hot where they touch the foam. the foam in cars is fire resistant and much more dense than what I have seen under boat skins. Also the kits I used have an temp sensor in them to prevent overheating. Kit for 2 seats (4 elements, 2 modules,and wireing) cost me $190.
09-23-2005, 9:10 AM
Brad how can you know if the foam in my Nautique is Fire proof? The foam is very dense and smooth. Im sure most manafactures us a similiar foam.
09-23-2005, 11:34 AM
Grant, it sounds like the same stuff as in a car. When I took my Tige seat apart it was open cell foam, real spongy prolly not fire retardent. So I decided against installing the heaters instead i sewed them into a seat cover and put closed cell foam under that now in winter I just put the seat cover on drivers seat and connect the wires.
09-23-2005, 11:57 AM
Yes I understand about closed cell foam Im shure the seets are closed cell foam. The kits that I have been seeing on the net look like they are in a heating blanket so the heating element would never come in contact with the foam. The say the are insulated a carbon fiber blanket surrounded by material. Did you have to cut the foam away and make a recess for the heating element so that it sit's flush in the foam?
09-23-2005, 12:11 PM
It is for real, and it is great! I turned it on the other day, my back was sweating in less than 5 min. Come winter I need to get back on the WakeWorld 2006 WSVLX to enjoy heated seats while driving the one of the best handling boats I have ever driven. And that my friends is a fact by the way!
09-23-2005, 12:24 PM
Most seats I did not have to cut because the element is very thin. I just measured one for a jeep gr. cherokee measures .293 inch the actual element is very thin wire incased in a thin wolven fabric and some foam looks like Kevlar? but not carbon fiber. You do have to cut out a piece of foam to keep the wire flush. Also you may want to cut down the foam for the element because it will not be covering the whole seat as in an automotive application. Oh yea the elements are adhesive backed the warning on the paper protecting the backing that you peel off says that if any paper is left on the element it will start a fire. claims surface temp over 400 degrees
09-23-2005, 1:08 PM
The company that makes the Malibu heated seat is Check Corp. http://www.checkcorp.com/seat_heater/default.asp
09-27-2005, 7:54 PM
I orderd some heated seat inserts for the drivers and passenger side. Ill post some photos when I get them.
09-28-2005, 1:03 AM
Keep us updated Grant! Brad, can you post some pics of your solution on your Tige? Thanks
10-06-2005, 9:41 AM
10-06-2005, 11:06 AM
Is this a special marine heater? What will it retail for?
10-06-2005, 12:02 PM
10-06-2005, 1:55 PM
yeah whats the price??
10-06-2005, 2:46 PM
You puttin' one in the observer seat too? Hmm.. looks intriguing, especially if the price is right!!
10-06-2005, 5:04 PM
Grant hook a brother up, I am in Michigan and the temp droped 20 degrees today High of 64 on Sunday. Let me know if I can buy some from ya. itch
10-06-2005, 6:59 PM
Rob: to be honest, I dont know what the heaters your link will and will not work in. I know this. I wouldnt mess with anything that is not proven, The heaters Im using have been used in boats for 3 years. The last thing ya want is a problem with somthing like this. Call Clay at the shop, He can hook ya up with a price. It depends on how many your installing. single or dule heater's. http://www.soundillusionsaudio.com Their is 3 diffrent seat heater packages Standard (1 temp) Luxury (2 temps) Premium(3 temps) all heaters have a 3 year warranty Joe Yes I put one in the passenger seat. Yea hows that gonna sound sorry honey I didnt have enought $ for the seat heater for your side. LOL
10-06-2005, 7:59 PM
Grant hook a squid up. Can we do some horse trading?
10-06-2005, 9:05 PM
Ok: Squid Ill take some wakeboard lessons from you
10-06-2005, 10:03 PM
Grant, lessons are free that is my favorite part about riding helping others progress. Seeing others land that trick for the first time stokes me as much as landing a new trick myself.
10-06-2005, 10:42 PM
what the number? with me moving to Wa in Feb this would come in handy......... Can't offer lesson though cause I'll only make ya worse.......LOL
10-07-2005, 8:54 PM
Grant, when we gonna ride? I need to try before I buy.
10-07-2005, 9:15 PM
Tim next week Mc Clure. I just finished. They are awesome
10-08-2005, 7:47 AM
Grant That is sweet. You da mack. When I bought my MALIBU, I was told that if someone that is wet and sits on the heated seat, that the dye from the shorts might bleed and stain the vynil, so I didnt opt for that option, But like you said when its cold outside your butt n back are warm. Hey what about a back and butt massager built into the seats
10-08-2005, 9:46 AM
No stains on our heated seat and as for the back massager Check Corp. has them too.
10-08-2005, 10:36 AM
grant, excellent!
10-08-2005, 10:38 AM
Where ever there is a stich I can see water coming threw. But I cant see how it would make a stain. Most of the time we have a towel on the seat So I dont see that much water coming threw. And at night when your going to be using them most I dont think you will be sitting on them with a wet suite. Im guessing when you have them turned on you will be wraped in a towel or have some clothes on.
10-10-2005, 12:37 PM
10-11-2005, 10:05 AM
wow, supa pimp
10-15-2005, 5:52 PM
Hey I have some prices for the heated seats. There are 3 kits. Standard Kit 1 setting $129 Luxury Kit 2 settings $149 Premium Kit 3 Settings $180 Each kit comes with 2 elements one for the back rest and one for the seat. Kits are pretty easy to install. All kits have a 3 year warranty Also massage kits. (you will need this after trying your new trick)Each kit has 4 motors and 20 settings with heat included. The massage kits are built on the Premium heat kit. Each seat $300 (Message edited by sound_illusions on October 15, 2005)
10-15-2005, 6:48 PM
bling bling!
