Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (extremeisaac)      Join Date: Aug 2005       08-25-2009, 11:36 AM Reply
so when you fill the boat with Oils, is the propper level when the boat sits on the trailer, or on the water?
Old     (rallyart)      Join Date: Nov 2006       08-25-2009, 11:56 AM Reply
On the water is the proper level with the oil warm.
Old     (zo1)      Join Date: Aug 2002       08-25-2009, 12:02 PM Reply
It doesn't matter... Just make sure that your trailer is on fairly level ground.
Old     (imscarlet)      Join Date: Mar 2008       08-25-2009, 1:08 PM Reply
All fluids can be checked on the trailer if level, if oil just make sure they are between the 2 marks.
BEWARE some gearbox/vdrive units need to be hot or have been running to check oil levels correctly depending on manufacture and model, read your owners manual!
Old     (airrantz)      Join Date: Jun 2004       08-25-2009, 1:30 PM Reply
If the trans is slipping add fluid if the v-drive light is on underway add oil to the unit. Haha jk check the trans on the water when the fluid is hot, v-drive and engine oil can be checked on the trailer on flat ground. Watch your knuckles when pulling the trans dipstick.
Old     (guido)      Join Date: Jul 2002       08-25-2009, 2:25 PM Reply
Almost all fluids should be checked when hot to allow for expansion. Though I don't think it'll make much difference on a boat.
