05-06-2007, 5:56 PM
Just wanted to throw this out there. I installed a Make-A-Wake in my boat. Got the RCIII and it works great. Takes about 8 min to fill 2 750s one tube sac and one integrated bow sac. Great system just wanted to lt everyone know. Very Satisfied customer
05-06-2007, 6:59 PM
Post some pics!
05-06-2007, 8:58 PM
i was lookin at those. glad to hear they work great like mac said post some pics
05-06-2007, 11:15 PM
Preston, how long did it take to get your system? I ordered mine on the 12th...but it's now been about a week and a half since I could even get him to answer an email...let alone a phone call ....last time I did talk to him, he said that he was waiting on some parts from a supplier.... but..... .....I would just like to hear from him...just to be kept informed
05-07-2007, 7:15 AM
I remember it took about 10 days for me to recieve my system, However there were no supply issues with my system. I ordered it back in Feb. so I think demand might have been a little low then. I have had nothing but great service from these guys they really are on top of everything. It would take a day or two to get emails back sometimes but that did not bother me. I was very impressed by the way that they system was laid out with all the wiring necessary and everything is labled perfectly/ I mean a monkey could install this system. The only part that I found hard was the through hull connection. I would suggest to anyone that does not feel comfortable with drilling and sealing a though hull to just have your dealer do it. They won't change that much and you can be garunteed that it will work fine. I did mine myself and everying worked great. I got a little over zealous with the 5200 and it does not look "clean" but I will say this the boat floats and there is not a drop of water leaking. I will post some pics in about 2 weeks. I know it is a while but when I went to the lake house this weekend I forgot the camera so I could not take pics. I will be backl there in 2 weeks so I will take pics then. Install time: Honestly it took me about a total of 6-8 hours to install the system. Now just to clarify I took my time a did not rush the install. I had to make multiple trips to west maring and home depot so that did not helps with the time frame. Also I wanted to make sure that it was as hidden as possible. I tested mant different plumbing routs and wiring routs until I found the best one. Also it was just me intalling and pullin clable a hose. I would suggest having an extra set of hands to help if someone is willing. That 6-8 hours was spread over about 10 days. Constant rain delays and work got in the way. Please feel free to ask anymore questions.
05-07-2007, 8:43 AM
good post Preston when I have dealt with those guys, they have been very helpful and great to deal with I have heard great things about the system and look forward to getting it I haven't gotten the boat yet....probably this weekend...but for sure before next I'm just trying to coordinate everything....and get the fittings I need before I need them if you guys from Make-A-Wake read this, please get with me to let me know the status of my order
05-07-2007, 9:15 AM
I also wanted to add one change I made to the system. As everone knows who has dealt with ballast puppy pumps the threaded outlet is 1/2" and the outer diameter is 1" hose barb. The system comes with 1/2" threaded hose barbs attached to the pumps. I took off the barbs and just clamped 1" hose sirectly to the pumps. I just feel that it would be less strain on the pump as far as pressure goes.
05-07-2007, 9:42 AM
Daniel just called me! sounds like his supplier slowed him down a bit, but things are good to go now! I know what it's like to be busy busy, and have supplier issues overall....a great guy to deal with and I look forward to using the system !!!!
05-15-2007, 11:28 PM
Daniel got my system today thanks looks great looks like install will be easy and straight forward now I just need the boat...check out profile pic Preston, did you lay the system flat on the floor, or mount it vertically on a "wall"?
05-16-2007, 6:12 AM
Cliff, I mounted the system flat on the floor. I did this for two reasons: 1. I was worried about the check valvue working properly. I know it should not matter that much but I just wanted to be sure. 2. I looked at mounting on wall locations and they just seemed to get in the way as opposed to under a seat. I found some great hose at West Marine that will make 180 degree turns and not collapse. I will post some pics on Sunday night of the install. Also saw the new boat cliff looks great you should be super stoked!
05-16-2007, 6:26 AM
I am Preston I hope I can wait the break-in period without going wack-o can't wait to do the install....I look forward to the pics thanks
05-16-2007, 7:39 AM
I would love to see some pics of your install. I am thinking about this system for next year. I found place to buy the pumps for $250 each, but want to see if it is worth the extra $$$ to have built for me or just do it myself. What is the advantage / disadvantage of transom intake vs the hull bottom intake? Hull bottom you can fill while on the move vs the transom but what else are the pro's and con's?
05-16-2007, 7:40 AM
Just a waringing to all of you perfectionists out there. I got a little crazy with the 5200 on my first go around and it is a little messy but I will say this: The boat floats and no leakage. (Message edited by phall925 on May 16, 2007)
05-17-2007, 4:27 PM
Cliff your boat pics look great, glad to hear all arived well. Coach, i will be gladd to help you out with the system. If you price the system as a whole wire switchs d blocks,, etc... The Make-A-Wake is less expensive and is already built for you to simply install. Preston good to hear all is well.I need to add that in the instructions about using 3/4" or 1" hose. Thanks Daniel Make-A-Wake.com
05-17-2007, 5:34 PM
Cliff, did you not get any ballast in your new boat or are you just adding more on top of it?
05-17-2007, 9:42 PM
Patrick I did get the full MLS system front, center and rear tanks I was told that a 750 fat sac in each locker would allow me to surf either side from the looks of this system....we will be full of ballast and ready to surf... before I will even be able to choose which playlist on the ipod I wanna surf to..... boat gets to the dealer in the morning might be in it, on the water, Saturday night!
05-17-2007, 9:49 PM
oh! thanks Daniel I must admit, I was pleasantly surprised when I opened the box .....the quality of the wiring, connectors, switches, and the system over-all is top notch! other sytems that I have seen or used on previous boats, aren't as high end, and certainly weren't nearly as plug-n-play as this one great job thanks.....I know I bugged you enough on the phone...ha!....sorry thanks again I will post pics sometime in the future
05-20-2007, 5:23 PM
Sounds Great Cliff No problem, that is what we are here for, Let me know If you have any questions Daniel Make-A-Wake.com
