Well, I'm not gonna say any specific amps, but if it was me, I would run 2 amps for those. 1 for the tower, 1 for the sub. (I guess 3 if you count the 1 you already have) That way you can set each amp up for what you want. Sub amp, you will want the lower freq. amplified. Tower amp, you will want the mids/highs amplified. And you should probably look at getting a second battery. You'll need to do that with an isolator, so you can charge both batteries, then not worry about draining your start battery while the engine is off.
