you can make it work w/ one amp...I like to put the sub on its own amp. Look into mono sub amps (class D) I say push the sub hard w/ close to the 200 RMS , and push the fusions w/ 175-200 RMS. THere are guys on here who run the fusions and can tell you how much power they need to sound good. There are alot of different wiring options you can use if your using just one amp. If just one amp you'll definatley need a 4ch amp. That way you'll have full crossover control on each pair of channels. I've heard good things about Zapco equipment
