Looks good. I havnt purchased my switch yet, I have been looking at some on iboats.com and westmarine.com. I would like a rocker switch that said fill/empty and ballast but I dont know where to get one.
Also, tonight I greased up the impeller (with some vinyl protectant for a test) and used thicker gauge wire. I was able to go forward and reverse perfect! Filled up a fat sac from a bucket and emptied it several times. Dang its fast too.
Anyways, next comes planning out how to run my hoses. I know that my fatsac in the ski locker will be easily filled and drained because the ski locker is slanted downwards and the pump will only have to pull about 2-3 feet to prime.
The bag that I want to put in the bow is another situation. The hose will actually have to go up under the top edge of the boat to be hidden and then back down into the bow. It will also be at least 15 feet long. Im sure it will fill fine but I dont see how it would be able to empty.
Im attaching on a drawing of how i was thinking. Any advice on how I could successfully set this up in a I/O 18.5 boat would be awesome.
I was thinking about putting a y splitter right on the outside of the pump that would have closeoff valves in case something busted.
