Old     (pierce_bronkite)      Join Date: Jul 2003       08-01-2003, 6:28 AM Reply
I just bought a 2001 Tige 23V and was not sure what the speedo adjustment is. My speedomter and fuel gauge are not working. Does this have anything to do with the Speedo? Thanks...
Old     (bog)      Join Date: Sep 2002       08-01-2003, 1:07 PM Reply
the speedo adjust is to calibrate your speedo with a GPS to make it accurate. fuel gauge is a common problem, they had to fix mine when i first bought the boat. check your paddlewheel on the back of the transom to see why the speedo doesnt work
Old     (pierce_bronkite)      Join Date: Jul 2003       08-01-2003, 1:35 PM Reply
I checked the paddlewheel and nothing is jammed or blocking the whell from spinning. I even put compressed air in there. Dont know if a their is a lose wire of some sort. Thanks though...
Old    jmccallum            08-01-2003, 1:57 PM Reply
There should be a purple wire running from the back of the ignition switch and then chained from instrument to instrument. It bring the 12Vdc to each instrument when the ignition is switched on. Make sure it's connected and has 12~13 volts on it.
Old     (pierce_bronkite)      Join Date: Jul 2003       08-01-2003, 6:02 PM Reply
Ok, I will try that.
