Old     (bobby_hottub)      Join Date: Sep 2007       05-18-2009, 3:10 AM Reply
I have finally agreed (at my wife's urging) to leave the boat on a lift during the season. There is a slip and lift available, but it is a Lakeland 2 tank rated at 4600 lbs. Will this be sufficient for our VLX? Our dry weight is approximately 3900 lbs. I suspect we will be getting close to the limit with fuel and gear.
Thanks for any feedback.
Old     (puamana)      Join Date: Sep 2008       05-18-2009, 4:50 AM Reply
From an engineering point of view, most of the lifts out there are under rated by as much as 25%just from a simple design standpoint. And it doesn't matter if its steel or aluminum.
Old     (big_matt)      Join Date: Aug 2007       05-18-2009, 5:02 AM Reply
Most of the lift manufacturers I have researched (still shopping)suggest adding 20% to your boats dry weight to select the correct size lift. This should account for fuel and gear, etc.
Old     (chuckc983)      Join Date: Sep 2008       05-18-2009, 6:00 AM Reply
I have a 2008 23LSV on a 4500 lbs two tank Hydro Hoist - I am not sure it would go up with the ballast tanks full - but works fine with a full tank on gas. You should be good to go.
Old     (bobby_hottub)      Join Date: Sep 2007       05-18-2009, 6:03 AM Reply
Thanks for the quick responses guys. Looks like I'll be good to go!
Old     (deltawake)      Join Date: Sep 2004       05-18-2009, 12:48 PM Reply
The Dry weight on a 2007 VLX should be 3600#.
Old     (bobby_hottub)      Join Date: Sep 2007       05-18-2009, 1:59 PM Reply
Thanks Peter. My dealer confirmed the 3600 lbs for me. Makes it even better!
