Is this a perfect pass paddle wheel? Everyone seems to think you have to replace teh whole unit. This not true. Unscrew threaded cap. Pull whole paddle wheel unit out. If little paddle wheel piece flaps around on the shaft, you need to replace the well. PP sells the shaft/wheel in a little kit. Press the old shaft out, replace wheel (Cups facing the right direction), replace shaft. Then drop the paddle wheel holder back in teh hole (ARROW the right direction), and tighten threaded collar by hand.
